Connecting to MA while using NDI
Dave01
Post by Dave01 »
Hi!
When using ndi I can not connect arena to my MA with artnet.
If I use static ip I always loose connection to the laptop backstage that runs the led screens.
Using 192.168.x.x
Subnet 255.255.255.0 (all computers) and
2.0.0.5/255.0.0.0 for artnet
How can I make this work?
Re: Connecting to MA while using NDI
I don't think you can have two IP addresses active on the same NIC.
Should be doable using an USB Ethernet adapter probably. You'd have an IP in the 2.0.0.0/8 range, on one adapter, then another adapter with the 192.168.0.0/24 range
NDI should route automatically, and You can choose the Artnet adapter in the Arena DMX preferences.
Or just set all the machines to the same IP range and addresses.
