Can't drag files into comp.
Bassindaniel
Post by Bassindaniel »
Hello!
Fresh Windows 10 pro installed.
Resolume arena 7.10
Program running as administrator.
Can't drag files from desktop/any other storage.
Can drag files from internal resolume file browser.
Little help here please :)
Bassindaniel
Re: Can't drag files into comp.
Soooo... quick update.
I just canceled the "run as administrator" option on EXE file.
Problem solved.
Yes, Admin context can't get data from processes which are not in the same context.
If you start your file manager in as Admin too, drag and drop should work.
Bassindaniel
Thanks for your explanation.
