Webserver problem
timvangucht
Webserver problem
Post by timvangucht »
Hello,
I don't know what's causing it. But if I start the web server and I click on the ip address, I get to the following page:
Access Error: 404 -- Not Found
Cannot locate document: /
Clip overview:
Cannot open document for: /api/docs/triggered
What can cause this?
Re: Webserver problem
Can you post some screenshots of the API settings?
timvangucht
Zoltán wrote: Fri Apr 15, 2022 09:42 Can you post some screenshots of the API settings?
Is this what you mean?
Is that IP address the same you see in the network card's configuration?
timvangucht
Zoltán wrote: Fri Apr 15, 2022 11:21 Is that IP address the same you see in the network card's configuration?
Yes I checked it with ip config.
Removing Resolume and reinstalling it didn't solve the problem ...
Can you try re-installing Resolume?
timvangucht
Zoltán wrote: Tue May 10, 2022 10:49 Can you try re-installing Resolume?
Like I said, I've already uninstalled and reinstalled Resolume.
I'm starting to fear that reinstalling windows will be the only solution.
Did you re-install with the 7.11.3 release?
Could you please send us the Resolume log file via the feedback tab in preferences?
