I'm running Version 7.11.3 rev 13855 on macOS Monterey 12.3.1.
I have a new Mac Studio M1 Ultra.
After I start Arena, the UI appears, then quickly the program crashes.
I've attached the logs here, it seems to just say that everything is fine with initialization at the end of the log, but then there's no specific error printed as to why it crashed.
I tried to remove my composition and start up with an empty project, but that didn't work.
I was actually running 7.10, re-installed with 7.11.3, but neither version was loading.
Wire on the same machine works just fine.
I'm not sure what else to try.
Arena is crashing immediately after showing the interface
- Attachments
- Resolume Arena log.txt.zip
- (3.97 KiB) Downloaded 242 times
Re: Arena is crashing immediately after showing the interface
Can you also attach the OSX crash log please?
Then try renaming the Documents/Resolume Arena folder and see if that helps with the startup.
ok, I see we were already in contact about this via mail too.
Chopchopchamcham
Was there any resolve on this? I am having the same issue. MacBook Pro 16 inch M1 64 gb RAM.
Resolume Arena worked fine during the tech run for the opera. Now it won't open at all. It just says that it's "not responding." Show is Jun 20th 2022.
Are you using mp4 files in the last composition?
Try renaming the composition, convert the files to DXV, change the root path of the mp4 files so they go missing, and open up the composition. Then you can replace the mp4 with DXV easily.
