I have an m-audio trigger finger and have plugged it into resoulme. I have assigned an fx (metalimage) and when I select a pad it loads the fx, but it loads it as 100% alpha. I know you have to hold alt click with the mouse to load the fx with 0% alpha. I have loaded the fx reduced it to 0% and saved it and reassigned to the pad on the finger. Same problem. It's also the same with keyboard assignment so I know it's not my midi controller. A VJ friend of mine has also confirmed this glitch, and he has a full copy, so it's not isolated to just the demo version.
Another problem I have discovered is that of the 4 faders with my 'finger I have assigned one to control the active effect's alpha opacity. But loading the effect the position of the fader isn't picked up upon until I touch the fader at which point it adjusts to where the fader is placed. Have I assigned the fader wrong somehow? Is there something I need to activate to make resoulme pick up where the fader is when it loads the effect or is there some conflict I can't see?
Does this actually make sense? Basically I wanna load various fx with different pads, but load them with 0% alpha so I can gradually add them rather than them hitting 100%. I also would like to control their opacity with a fader but have it load at whatever the fader position is. Is this causing a conflict? I have loaded the fx from the pad with the fader NOT being assigned to get the same 1st problem.
The other 3 faders control the opacity of the 3 layers. They also need to be touched before resolume will pick up their positions.
other than that can't really find fault. But this would limit this wicked program in a live environment.
Operating System: WINXP PRO
Processor: 1.4GHZ
Videocard: SONY VAIO STANDARD
Version: 2.3
