Zoom bug on beta 3
eXhale_
Post by eXhale_ »
Great job with the beta 3, I LOVE the new 'Ad' effect for mixing layers, makes everything look so great! :) And the barshift effect is exactly what I was looking for.
I just noticed that the zoom effect seems broken, only the bottom part is zoomed. It's an interesting effect but a normal zoom is useful too... :P
Also would it be possible to save the effects parameters on the deck files? For example if I apply a 150% zoom on an image, save it in a deck and reload the deck, then the zoom is back at 100% (ie. no zoom). I have a lot of samples which must me "pre-zoomed" so it's important to save time.
eXhale_
Post by eXhale_ »
Strangely it seems the problem is gone now, the zoom function works well today... Don't know why it happened in the first place.
kat_
Post by kat_ »
can you explain what the 'Ad' effect does? And what is barshift?
Kat
japani_
Post by japani_ »
i'm joining with kat's questiont...?
