Dante virtual soundcard
mouga007
Post by mouga007 »
Im having problems with Dante virtual soundcard on resolume 7 .
I have 2 computers One with Cubase sending timecode via Dante to another PC receiving that timecode by Dante .
I select the Dante virtual soundcard áudio driver on resolume and the smpte port and everything works well for a random time ( could bem 2 hours or 10 minutes ...) And then it loses the timecode ... I go to preferences áudio and the áudio driver appears in grey and the smpte says no input ... I select no driver and then select again Dante virtual soundcard and everything works again weel for a random time and do the same...
It seems like resolume Lost driver connection for any reason i can not find !
Im using win10 on a PC with Cubase and win11 on PC with resolume
Any ideas to Help ?
Re: Dante virtual soundcard
Where does your Dante master clock come from?
jolson
Post by jolson »
We use Dante for SMPTE input using Virtual Soundcard which works flawlessly, when the source is from Ableton playing back an audio file with SMPTE timecode. However, it does require a master clock which might be the cause of your problems. Additionally if you're using an audio file you might want to ensure its a lossless format such as WAV. It wouldn't surprise me if some of the MP3 compression formats might cause some unexpected timecode behavior from lossy compression methods.
