Can't rename me decks!
Anonymous
Post by Anonymous »
Hey there, after re-organising some of the JPEGs in 'My Pictures' (Windows XP) I found that those stills already loaded onto decks in Resolume would no longer load into the mixing layers, I figured this was because i'd moved the files(?).
I've created new decks with said photos but now, when i try to rename the decks, when i press delete or backspace, resolume is cycling through the mixing layers, activating each one in turn. I might have tried to set either of these keys to this function in preferences (but i can't remember for sure if i did).
What can i do???
from
unzenGlen
you need to go into the prefrences window and make shure you do not have the backspace key assigned to something. let me know if that helps!
Anonymous
Post by Anonymous »
Hey Bart, yeah, it was the 'move layer down' function that was activated when i hit backspace key but i had the 'end' key assigned to that function, i guess these keys are linked(?). Anyway i got it all sorted now so thanks for your help. Amazing software by the way, can't wait for the new BPM function on 2.4.
unzenGlen
