[quadro rtx 4000 8gb or rtx3060 12gb)
flippy
Post by flippy »
hello.
arena use more gb on gpu or cuda core?
format released 4k screen
input 4 sdi and video file mp4
3060 V2 OC Edition Scheda Grafica, 12 GB GDDR6,
which of these cards do you recommend?
flippy
Re: [quadro rtx 4000 8gb or rtx3060 12gb)
Post by flippy »
in alternative VCNRTXA4000-SB
NVIDIA RTX™ A4000
"gpu or cuda core?"
That's the same thing. Are you referring to openGL vs openCL?
Quadros are great for when you need to sync multiple outputs to the same canvas (to prevent screen tearing), beyond that, they are overpriced for what we do. Also an 8GB Quadro is NOT the same as an 8GB GeForce card you'll need about 12-16GB of a Quadro to equal the performance of an 8GB GeForce.
So if you don't need to sync multiple outputs to a single canvas, I'd stick with a GeForce card and invest that $$ elsewhere :)
