What is the best way to make the clip turn negative and strobe?
Is there a freeframe out there that does this?
Or would a swf or seperate flashing balvk and white avi need to be created?
Any advice is appreciated
[Edited on 17-1-2006 by VJDefinitive]
negative strobing
continuity-B
Resolume has a strobe called 'stroboscope' in the sources tab
You can adjust the colour and speed of the strobe by right clicking it on the deck. Just change the blend mode to change how it affects your video (Scr or Mu for a solid strobe).
Blend this with your desired video, which you can invert using the standart 'invert' effect.
Hey presto.
Hey presto.
