set all transition layers duration to specific value in one go
yslimi
Post by yslimi »
is there a way to set all transition layers duration to specific value in one go
during the performance i have several layers that i would like to blend slowly from one to another and i have to go to each layer and set the transition to specific values, say if i have about 7 or 8 layers , then i need to go to each layer and set it individually. this is taking too much time in live situation.
i don't know if i missing something here, is there a way to set all transition layers duration to specific value in one go, please advise. Thanks
Re: set all transition layers duration to specific value in one go
yes, keyboard or midi shortcuts mapped to the same key in mouse or Value mode,
or OSC message to /composition/layers/*/transition/duration should do it.
yslimi
Post by yslimi »
Thanks i mapped all to the same keyboard key , this helped a lot
