resolume as second monitor
mrkavin
Post by mrkavin »
First of all, I'm very new to resolume, I'm trying to find advise about the resolume. I have a Unity game that required another app to run on separate monitor (just regular 21" monitor), but I would like to display just Unity game on multiple blending projectors for panorama view.
My question is
1. Resolume can run on the same PC with Unity?
2. Resolume would consume much of CPU and GPU if they are run on the same PC?
3. Can I use separate PC to install Resolume and treat Resolume PC as receiver from Unity PC then send output to multiple projectors?
Thanks in Advance
Re: resolume as second monitor
1. yes,
2. Resolume would consume the same amount of CPU than when running on a different machine, the actual amounts depend on what you'd be doing in Resolume.
3. yes, Resolume can accept input via NDI and capture cards.
mrkavin
Post by mrkavin »
Thank you for you reply, I really appreciate it. But, can you give me link about NDI and Capture card and documentation please.
The Resolume NDI side is explained on our support page here https://resolume.com/support/en/NDI_inputs_and_outputs
If you're running both your apps on the same machine I'd recommend syphon/spout instead: https://resolume.com/support/en/syphonspout
