dramatic framedrop
ats
dramatic framedrop
Post by ats »
hi,
i'm using the last arena version.
The specs of the pc are :
Motherboard: Asus ws299pro
Chipset: Intel i9x 18cores 3000
Ram 8 Gb
Video card Amd Ws6600
Acquiring card Blackmagic quad duo.
Composition in 4096*2160 and should run at 50 fps
Over 4 output 4k present on the amd card, i'm using only two: i have connected one ledwall 3840*2160 and a blackmagic hdmi to sdi cross converter 1920*1080
as soon as i activate the second input, arena falls to a framerate between 27 and 32 fps.
Cpu usage is 3%, Ram usage 30% and gpu working at 35%.
<i have the same problem on another pc, same configuration, using 2 outputs at 4k.
What the hell could be? If on the same machine i use another mediaserver software, it works smooth..... !
Re: dramatic framedrop
Do you have all the displays connected to the AMD card directly?
ats
Post by ats »
With two active converters dp-hdmi .
Tried even with a matrix, but I got the same result.
As soon a I activate the 4k display in the advanced output, I get more or less 28 FPS., Even if nothing is connected to the and GPU
Where is your UI monitor connected to?
If you enable Show display info in the output menu, and enable the outputs, what does the Renderer an GFX lines say in your output?
