wire
VJ muhou
wire
Post by VJ muhou »
想跟各位vj老师们请教个问题
在使用resolume wire制作特效的时候
需要添加一个什么样的输入节点 做出来的特效才可以载入电脑中的图片
就像 mask 与 uv map 一样
I would like to ask a question from the teachers
When using resolume wire to make special effects
What kind of input node needs to be added to make the special effects to be able to load the pictures in the computer
like mask and uv map
Re: wire
Are you trying to load the image in Resolume or Wire?
