Global Dashboard
Bassindaniel
Global Dashboard
Post by Bassindaniel »
Hello!
Please add an "Global Dashboard" area which the user will be able to attach any parameter to an "always on" dashboard.
:ugeek:
Re: Global Dashboard
Like the composition dashboard?
Bassindaniel
No.
composition dashboard is only for composition FXs..
I want a Dashboard that can hold parameters from any ware in Resolume Arena.
not only Clip, Layer, Group.......
Sorry, not following, where else would you have values coming from if not clip, layer, group?
I think the point is to be able to assign a set of clip layer or composition level parameters to a single group of dials, you can map, and have always visible, right?
Currently the specific level dials are locked to params from the same level.
Weird. I swore you where able to map clip or layer params to the comp dashboard. hmmm??
Well another +1 for global presets <3
Bassindaniel
Zoltán wrote: Thu Oct 13, 2022 14:30 I think the point is to be able to assign a set of clip layer or composition level parameters to a single group of dials, you can map, and have always visible, right?
Zoltan, Yes that’s was exactly my thought.
Avrol, I’m so glad you finally understood me.
