Greetings!
On my Twitch streams I have Resolume connected to OBS through Syphon, and it works fantastic to trigger clips via MIDI from my Launchpad.
I want to find a way for viewers to use channel points to launch video clips themselves.
I have used Triggerfyre a little bit in the past to launch stand alone audio and video clips, but I'm wondering if there is a way a viewer could redeem channel points, which would send a MIDI note to Resolume to launch clip?
Much appreciation in advance for the help!
Is it possible to use Triggeryre to launch Resolume clips in OBS for Twitch stream?
coxo@uci.edu
Re: Is it possible to use Triggeryre to launch Resolume clips in OBS for Twitch stream?
Here's something I wrote that converts Twitch chat into OSC:
https://pixelparty.gumroad.com/l/twitch ... ixel_party
coxo@uci.edu
Wow! This is very inventive and will be great for chat engagement!
I do not use Touch OSC. Looking through your video now. I'll take some time and try this out.
Thanks so much for creating and sharing this!
