Resolume Arena 7: Application failed to initialize (OpenGL issue)
avvebo
NEW USER:
Post by avvebo »
I have a macbook pro, but upon trying to open arena it fails to initialize.
Maybe I need to download this OPENGL v 4.1 thing?
Any help is greatly appreciated.
Regards
Re: NEW USER:
Opengl 4.0 is not something you can download on a machine that doesn't support it unfortunately.
You'd need at least a macbook from 2012 with Nvidia graphics to be able to run Resolume 7.
Which macbook do you have?
sooohoooo
Post by sooohoooo »
Hi, I'd really appreciate some help!
I have been using the latest Resolume Arena versions with no issue, until today when this popped up upon trying to start the app: Application failed to initialize. Make sure your system meets the system requirements, eg OpenGL version 4.1
I recently switched to Windows 11, but have used Resolume with no issue since then. I am currently running the latest Nvidia Drivers (526.47), although the issue popped up today while I was using the previous nvidia drivers. The new one did not help. I have also tried restarting the PC, uninstalled other recent installations (nothing serious changed with my system since Resolume was last working), and uninstalled/reinstalled Resolume arena, as well as rolled it back to 7.13.1. Here is my system:
Razerblade Stealth 13 Late 2019
GTX 1650 with Max-Q Design (4gb vram)
Intel i7-1065G7 CPU
16 gb Ram
Here is a copy of the Log from my last attempt to boot Arena 7.13.1 (same issue with 7.13.2)
Resolume Arena 7.13.1 16350 built 26 July 2022
Log started: 3 Nov 2022 12:57:19pm
[2022-11-03T12:57:19.831-07:00] INFO: Logging has started
[2022-11-03T12:57:19.836-07:00] INFO: Ensuring Nvidia profile correctness
[2022-11-03T12:57:20.071-07:00] INFO: Failed adding application Resolume Arena/Arena.exe to custom nvidia profile, it's probably already present
[2022-11-03T12:57:20.071-07:00] INFO: Nvidia profile setup finished successfully
[2022-11-03T12:57:20.094-07:00] INFO: Initializing application. Command Line:
[2022-11-03T12:57:20.094-07:00] INFO: Initialise JuceResapiApp
[2022-11-03T12:57:20.094-07:00] INFO: Initialise ResApi
[2022-11-03T12:57:20.094-07:00] INFO: Initializing Resapi
[2022-11-03T12:57:20.095-07:00] INFO: Created ParamCollection
[2022-11-03T12:57:20.095-07:00] INFO: Created TaskManager with 6 threads.
[2022-11-03T12:57:20.095-07:00] INFO: Created InputController
[2022-11-03T12:57:20.096-07:00] INFO: Created DeviceChangeDetector
[2022-11-03T12:57:20.096-07:00] INFO: Creating VideoFormatManager
[2022-11-03T12:57:20.096-07:00] INFO: Registering basic formats
[2022-11-03T12:57:20.097-07:00] INFO: Registered 4 formats
[2022-11-03T12:57:20.097-07:00] INFO: Created VideoFormatManager
[2022-11-03T12:57:20.110-07:00] INFO: Could not create instance of IDeckLinkDiscovery - DeckLink drivers may not be installed or not up-to-date.
[2022-11-03T12:57:20.114-07:00] INFO: Trying to create DirectShow capture input device for: Integrated Camera (DirectShow_\\?\usb#vid_13d3&pid_56d5&mi_00#6&20f9b466&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global_Integrated Camera)
[2022-11-03T12:57:20.286-07:00] INFO: Trying to create DirectShow capture input device for: OBS-Camera (DirectShow__OBS-Camera)
[2022-11-03T12:57:20.288-07:00] INFO: Trying to create DirectShow capture input device for: OBS-Camera2 (DirectShow__OBS-Camera2)
[2022-11-03T12:57:20.289-07:00] INFO: Trying to create DirectShow capture input device for: OBS-Camera3 (DirectShow__OBS-Camera3)
[2022-11-03T12:57:20.290-07:00] INFO: Trying to create DirectShow capture input device for: OBS-Camera4 (DirectShow__OBS-Camera4)
[2022-11-03T12:57:20.291-07:00] INFO: Trying to create DirectShow capture input device for: OBS Virtual Camera (DirectShow__OBS Virtual Camera)
[2022-11-03T12:57:20.293-07:00] INFO: Creating DisplayCollection
[2022-11-03T12:57:20.294-07:00] INFO: Created DisplayCollection
[2022-11-03T12:57:20.295-07:00] INFO: Successfully setup Resapi.
[2022-11-03T12:57:20.295-07:00] INFO: Initializing Resapi graphics
[2022-11-03T12:57:20.295-07:00] INFO: First time OpenGL usage, initializing extensions.
[2022-11-03T12:57:20.295-07:00] INFO: Registering window class.
[2022-11-03T12:57:20.295-07:00] INFO: Successfully registered window class.
[2022-11-03T12:57:20.298-07:00] ERROR: ra::Context::createOffscreenContext: Advanced context creation function unavailable.
[2022-11-03T12:57:20.299-07:00] ERROR: Escaped from error in ra::ContextManager::initialize(26): Failed to create primary context.
[2022-11-03T12:57:20.299-07:00] ERROR: Failed initializing Resapi, Contexts are required for rendering.
[2022-11-03T12:57:22.957-07:00] INFO: Initialise took: 2.86273 seconds
[2022-11-03T12:57:22.957-07:00] INFO: ***
[2022-11-03T12:57:22.957-07:00] INFO: Shutdown sequence started
[2022-11-03T12:57:22.958-07:00] INFO: Shutdown sequence triggered because another instance is already running or OpenGL 4.1 is not supported
Re: Resolume Arena 7: Application failed to initialize (OpenGL issue)
Do you have Resolume assigned to run on the nvidia?
richddt
Re: NEW USER:
Post by richddt »
Same problem for me! It used to work fine about a month ago, now the same error appears. This is on a 2018 MacBook Pro 2.6GHz, 16GB RAM, Radeon Pro 560X 4GB. macOS 12.6. Any suggestions?
