Ventura ? & extended display issue
ricoca
Post by ricoca »
Thought I had sorted the Mac o/s and Resolume issues I was having re opening to full screen on an extended display ..aka a TV ...
HOWEVER since upgrading to Ventura when I click on open display full screen on the extended display nothing happens .
8-) If I try using the windowed option it will open on the main display windowed which I can the drag across to the extended display and drag to full size ... however this is not ideal ... obviously
So I am guessing it was the upgrade that has put a spanner in the works but could have been something else ..
Other apps such as Resolve will open a full screen onto the extended display without issues ...
Re: Ventura ? & extended display issue
ricoca
Post by ricoca »
Perfect //
it was a deal simpler than the above just a matter of RT clicking Resolume icon and in options reassigning from desktop 1 > ALL desk tops
THANKS !!!!
