Advanced Output skips
Room26
Post by Room26 »
Hi!
I'm having an issue with the latest version of Arena, from a Mac Studio (M1)
basically the output goes to black, and the only way to quickly get it back is Disabling the Output and setting it back to Advanced (win-shift-A to disable, win-shift-D to set it back to Advanced)
I work with 2 1080p outputs, sometimes one jumps, sometime the other one, sometimes both...
It happens only with a certain composition, but I can't figure out the issue...
Has it happened to anyone, or do you have any tip or suggestion for troubleshoot?
Re: Advanced Output skips
Does the Composition preview also go black?
Do you see the main display flash or resize?
Room26
Post by Room26 »
Zoltán wrote: Wed Dec 14, 2022 08:47 Does the Composition preview also go black?
Hi, thanks for the response :)
Composition preview stays lit and control display doesn't flashes nor resizes
What are your output devices and how do you have them connected?
Airplay or sidecar displays?
