The projector reduce brightness when use Resolume
kevin
Post by kevin »
Dear,
A few days ago, we tested our new projector and feel the brightness not good when output from resolume.
We measurement if output direct the brightness ok but when use resolume software it reduce 25%, anyone met this symptom before?
Hope anyone can help, the brightness very important.
Many thanks,
Re: The projector reduce brightness when use Resolume
kevin
Post by kevin »
Zoltán wrote: Tue Dec 13, 2022 10:39 Check composition master https://resolume.com/support/en/composition#properties
All opacity master is 100%, so that why I feel strange. I used resolume for a lot of project never measure until we got some new projector and tested it.
knappy
Post by knappy »
I had something like this happen and realized that my advanced output had the brightness down for that screen... just a thought.
