Reprise from where left when triggering clip
cocconat
Post by cocconat »
Hello,
I am using a MIDI keyboard to trigger a set of clips.
I have the clips on the same layer. I want to select the clip with the keyboard and reprise the clip from where it was left when I switched to another one.
Instead, the present behavior does restart the clip from the beginning of the timeline everytime it is triggered. The behavior is the same, both in piano and toogle mode.
Is it possible to not restart the timeline at trigger time? Could not find any option for it so far.
The reason I want to do so:
I have 10 clips that depict a continuous travel in 10 imaginary words, I want to switch between them to give a sense of continuity and overlap, and follow the beat. But if I restart from the beginning each time, the effect is gone...
Thanks for your help,
cocconat
Re: Reprise from where left when triggering clip
