FPS Dropping to 6 . Hardware solution help required
arunconjeevaram
Post by arunconjeevaram »
Hi Guys,
I'm Arun, and new to the forum and Resolume.
Resolume Version 7.13.2
I have an ASUS mother board ATI Form Factor (Prime x299)
64GB Ram
2 x AMD - WX 7100 pro (8GB each) - Total 8 4k outs
Windows 10 Pro (1TB SSD for C drive)
I have 7 Projectors (1920-1080) and a Monitor (1920 - 1080). Using all 8 outs
When the Advanced output is disable, the FPS is 60. The moment I enable it, the FPS drop to 17 to 10 - and even to 6FPS
Videos are DXV3, and also capturing 4 inputs using Deck link Quad HDMI
Please could somebody advice me on what is wrong, also if you can help me build a new system with recommended hardware to run 8 4k outs (2 Graphic Cards)
Online
Might as well join the team
Re: FPS Dropping to 6 . Hardware solution help required
Those GPU's where built 7 years ago when 4K wasn't really that big of a thing. If you're wanting to blend outputs into a single canvas look into a RTX A6000. For everything else, a 3080ti is a killer GPU.
arunconjeevaram
Thanks for the reply. Having two A6000 cards, is it recommended?
Online
