Clip time countdown
nmugnaini
Clip time countdown
Post by nmugnaini »
Hey hey
I have a problem with the clip time not counting down the correct duration time of my clip. Adding anything without a scrub-able timeline automatically defaults to 5 sec. If I make the duration longer or shorter the clip time window doesn't adjust to show the correct time; it looks like it speeds up or slows down based on a ratio of the set clip duration.
I hope this is a bug, let me know!
Cheers -Nick
Re: Clip time countdown
Could you share a screenshot of the clip panel?
elgarf
Post by elgarf »
Clips without transport, like images, always show 5sec duration on time panel. It just tick faster or slower according to real clip duration, setted in the clip properties.
nmugnaini
Post by nmugnaini »
Can I ask why it's constrained to 5sec? Currently, how would you use the Clip Time window when everything is 5sec?
The constraint of 5 seconds makes countdowns over comms and other triggers/event very difficult. The notion that a second isn't actually a second is, in the video industry and in my opinion, truly a bug.
nmugnaini
Post by nmugnaini »
Just updated to v7.16.0 and this is still an issue. Duration time does not match actual countdown time.
When will this be fixed?
andrewspalomino
Post by andrewspalomino »
It's September 2025 and it's still bugged. Why haven't you fixed it yet? I can't set a duration on a camera or a still image. Resolume only works with the default 5 seconds and doesn't save it after all the work of changing the composition. My version is the latest released.
Works fine for me in the latest release:
nmugnaini
Post by nmugnaini »
Hey I just updated to the latest tonight. Still buggy for me.
Christoph
Post by Christoph »
Works fine on my end with Arena 7.23.2 as well. Is this an existing older composition with the 30s already set or is this with a new comp created on 7.23.2?
nmugnaini
Post by nmugnaini »
Ah, you're right these are only affected by files brought into 7.23.2, new files are working.
Still seems like a bug that older files can't work. I'll have to recreate a dozen compositions.
