Looking for Resolume Wire programmer
I have a very specific plugin that I need designed in Wire, looking to hire someone to implement it. Please message me if interested.
Re: Looking for Resolume Wire programmer
It would help when you describe your project with some short words.... you dont need to get very detailed!
Best wishes
Best wishes
Do you like outlines? Easy Outliner on Juicebar Re: Looking for Resolume Wire programmer
I'm looking for something that can draw lines using MIDI control to adjust the angles, lengths, etc. I would prefer an effect but I suppose a source would also work.
You can continue to copy past the UI elements on the left, and just add more instanced counts on the Join Nodes to add them in.
Code: Select all
--begin-wire-patch--
1621.3oc6ZssahiDD8WIxOai5p6pu34MtEoc0tZGsy7vtJJOXvNAqgXGAl4xNh+8sZeIX.iMP1QJrCIBSh4zU6tNmp5pr46NSSSRhllEmlrz4c28cmGVj9D8GfqS5prmWk4buqSVp8LLWmkyBdNx490tufisGNtqSbBcB1V3DGDGrENbOb9MZO4Awss836uNnk1zYAzpd91lzeen7C.UsOTwAfp2GJd.nPCNcWmIQOFmrMNdS3hRB2FE1HE9TPVzh3f4ai8EZjsArrzgtMx8IRP0HPUCljdeV7zOkDsb41fM6KOvF4cv+vH2g4aPZJazlb3vH2wlXaxocvJaSOsCVdaBpcvJZSQYwde40tMf1g435HnWH8RRuTzKM8BL1C9zAtEBGrG31CBqcSRCinw+cZ7zgfrrEwSVkUbpGlm9E66YeiRF7th+004yAyWY+2kwOlPxq0tNyBV58TvWqAcRZ57MPyVrJpBFIw6.VbxxrfjoEWBk.SV8zjnEafBqsB7u1EhslrcQ3AqILSRWkDlOUyhhebVly6LDG8k3vrYjQDj1hlE532niD7oyCVliNNjLoVq70bkzaDWH8v9p9dCTJviw6OXrTNTyu8V6DFsXIk2sxBoS+DM1OGGFkRe3zz4oKrdW5GU.ikepbWPVwDkGwsEKDjs6pXVbXXThUFTFfRDavSV3eHKXQ1M+0Mfknf843iwaya1QAL0FOkuL2SAbj0i7HJaTQ69rfPcfG9.BdlPk1SghIOf9OviBvWqOqHU5N9L9lEzc24w5grhej9JFpPz31v4t283gRAu4ImaadaxVdMOuGMT67tIc6AUJjAYbYwfEZtj6yDtMbt62RPsQI8awIQ4hnFxTPNdZql3kwIO5EFunnNiZWJSmkFOMpVxieIwZpIwYgQOa0OGF46CxlN6lAwY2LJG55MasQS0SQIKKJo4EKT6jaV6bqSZQzxz4q55RqXB+P7+juZyqD5zlnFCVjl8iUjJ0QFqLtOW4g5QJOeijRxfijiFJ.bvs55wJvYDqTRcAVt6vhGrlaeWTXcAN3l+Koeq9q6q7h0F2yKRmFEtZQPsz+2krZ9bW6gsUfaeEVKyl0l27mTDGkqxpKgyeGLJimW4FqsmHzs7idAR9aaLYYDe26rTpAjFcOIy2GMZAENazERAJNmCZethhNE9LRgbXsgPK3dHOLvSIEQdSTHDhAnOm+pyi9R0qsjRi4xrL7KkkzEzlSt7qow4YD.9EJIpXFlfyqENaD8.vWvEUL6OKTn3sBEdJLnomOh9nhaxC2xYPfxOy.lALnAPTJf2XwgaVvrV3u5n5f5v2JTGdJbGsKpFXRMTm73HkYkXBkQI4BT7FK9C2Nnh9EZKFrQ3cPlxyqZ+iosHdQALFedOInkZCTUCSOTpDbeAJ0r1iWFLdbeObjv3YFOV5wFOnONbvHV+wi+utmornulsZQDObypzVmwAbfer.8M+AYCqeTc9AE1V4ssFepUp9x3NprbU3iSNu4gF2QNO4N1ScRJFzQNCK+TzWN0IHeLGo8yROG9nbTmvbb5bQ4nN+80.ItWxQe.6IDHpqUXBnDz1ZFlD.TiJleq4F884i7PFhdF9ngdi3iYiDrQ2pMu5vzJUdK8rBEoEqzos0caQQLcb6RpfYkLs1prjZMVtg5aEK2BlK2PhcM+Mm242CdNOei45ch6f2INOnmPgRFouEU64f9POsvHPN2HAYqMK81+F0wy0.9W0.mjFPpEWBZ.VOJU6QHC96BYvqnY3ik2dlLezhVugXO.dO.Ge83bEuyam0PjX.ZeDpHvAJugJy.TM1vXC5WmA3mKCzQiRkOvmStMo2GPWJqyePJWiNOknSkTdADc1QB5wIgUom4vUAvII.zB8Ef.n6ryVMPUtY9OaZ.1qRBX.+KBI.T970.zmAfB3sqH9X0CdqTUH9Quk8qgCnUzQyA3P+wd3sZo2.7VlmDA4.MHF2GF7CgC18NbA6dGt1y0OzNMktc7xrRIVOkPh9lZO5mSoalK85njWprFrKqcJ8ebgyZhq09zwWTHC+xr5lpdOy+tBgWo4NnYPgWrswjSwxqTbGTLGUWn2GohNUxoY00FUZmkEby+y5EIm20uUZEovKi.6sY2FPSOO8CzsQti0+xrrUnmryxStnqMs7q34pEE920q+W.S.epoB
--end-wire-patch--
I’m looking for a plug-in that will draw lines similar to the ones in this video. Those were pre-recorded, I’m looking for something that works in real time, preferably in sync with the pitches from MIDI notes… https://www.benneill.com/portfolio/fathom/
Do you want the audio to draw the Y value while the X value is on an automatic path? Or do you just want to draw it with a midi controller?
I think MIDI - maybe MIDI notes could be used along with controllers which would enable pitch control.
Give this a shot. Map your MIDI to the Y param.
Code: Select all
3093.3oc6bs0iZijE9uRKdlxppScOuw0UyCi1nYFsRiFkGLfIsUnsYAyjz6n9+9dJaCXiM1lFxrc5kNhjzliqpbc9N2Ok+qdyiihBlmDFGss2G9i+p2xMwOg+Ga+d9aWiewFe7658o98RhwKyf98BiVuKg16Suz+.0Ld+dw6Rxt9dRY4jxJSJz.omLp6o7Hgz93WF7u2EDM+4RzBUoUjOnkniWkNY+dO4mDrIzeUIRE0RpeTBRXn+1vnOWd0Jp4AS0u2F+Eg61VlzZdxz3+Yiez1Ut86nxjqpk7pObtqVyRd6i9qCJSnrl0pod9ko5XZqkcIqPHPqcUVcDAVsDZqtJAnyTxqcUBPCjV9QGpArreSBJSYUrhadNKCsJ0x5drfZX7PsK0pD5t2sAqxDsaiV94nslUZ8HOZUBM0J+QqckVCipJVFrmaYVkV27TOsfs5.KpcETEmxw8iMAaS72bxSExUVux+4RDlcghyLsJziWOJkWcimWOHkyqWTNds+7vjmOAmVibOXqG7qafTZaLeNs9A0TyN.s1AslwrdtDuN8t7ZwdxZGyE61rWD8S42lyTXOZu98X3G.+vwOB7iD+nvOZ7iwccoanhhWDf2xeg2B9W9IIaBmsKI6RKWE+U2+l7LpC9CY+Z+d+o+pcteca3miPyNuzu2i9aIO4+sBjNKNd0QRS1rKXOYgQsQVXDBRilmsDxILZ2SyB1bjT1KNCeeqMJJMYmRA8EjjYw6hVjNSOFD94GS58ACJO70vEIOhigi+hSBgA.0SJLBEyxDTkCK9buOX4dTNiBLFyvToWGGx4q72lNhgKvYUqUVMnjjw.WRDCTCHCUJFgBCFNQJGogoScqofMac7QbU4Fg34eAu2+LbQPL9kyiWEuww.veT9TZ5kR2kRxlnT3RIFkeRgGTOo6Q8wvEKBhbnib3Ex78exQ+u6Xhr67+13+Tlhw3fgky+YZgm1fLWtgZjVt9MI6m0Ly+WWGDrHE.TiF.mGijTWFOKWao+psWBaaWT353U9aZY.qk2HMG4MVYFuwpndLEUPob6AISlj5YEJIETFoTnLMwZlZkSIB1XCwLcjfLdJc7HoZBiJYWKqw+o0qBS1sHnI1Sw3BZPHNU4R7xkaCZRVGoYMJnEP5Bkn+.AIjT5KPHB.97mKx1h1sZUYPzwmqSltCqvxCdA3l+WSAaWg5lthzViCevlhp.l+Xb37fBC5RFYIqW6JBxAaJMyC0Bv.NMESkh0LZOs1ZUnh.ll0HRaxHApDfNlSFNYnhLRYFJTSLT5vAEQZvqUI.sY1ctWMMPSQl7Qd1G8wkhioAWCSys9HKBeJHZaVD6GtoBW7vs9Ge5vB9Buosg+mfFPFtMW2WUbuJ8eJfJR2Vxoi0JccE8vEfm.nBFkI2qnxX7zRivhtUHkTsyzx4gOCnnNJAXGPFHkFhxNbjzLlNV.xahMDZyZoZC9vNC74m2sJIb8pmSgP7WODx4JryOiKDOb31xHrUldF8gQupoAusNNMo6luF4gtNAa+RvWuTQG2szwgOI9UvKxuoKXJtX9P9M0oonVIWmSeUjbEdJKWQ4xihtNu+.N9UBfwMpVT8asvXT0uPPLv3Qn6fSPy.zwS0lIWqr6d.da9XjgO6fIhlIwARZNXi874ySEgcfS0YGWO7.bTjt2gA4vTlu9Jn8wecphGwcEO2U77ilhGhUZ8DRJ9678QcBLzITqVYnp1x4vckNkohQy9gIrnW7JFzAsPTOJ0l8CtuJLfzbS0KIqOpaLnaWYZPL3l7DA2PXL+TjanlElrHXsC9bdJ+nex7GeXXXxCiSI8kiEP5Bg6X3cwq101JKa99UmK4ujWMmKZd5pu0LLVeOISqokjUP2qsFEfRKTMZlt4fyF.JhPOVQrF4.xPwX43QblX3TcQgE1qIM.EK71YQZhBLiSoRTXWg0O8OeZ+FZAZWuIddfKovqZH58BAi6t8G9kfnEXDRNvnpJXraQa20z0fBQdZEiKAYgz03hBBUSoMYtWcA7nQClTCO50nPKuVmcNKpG2EGEtY9pT7MSekAH2h0iBr2KHOHEJkWWrNA85L2jwAvw4LBgi8bfcp8P8q71bIlFH8IhYKWPlgDSBDKUlOxmOWn3Wq.2oVTNqbQ4BcdByGJHzQ6S+z4huM9Oy39lpb+WoN4LvvbjGjzRpL5JH3xUWWKHfQUUQAn5UOCBBzLk1dLuXFOg.u.nn6E1aH0FflRDiUThkwFQFXLCYCmn3J6fqUvd1yqymxVxe8IY2HI3aI61D.Kp.YxqhdWH8o3R49MLJInTpUYNdSd8NYM6K0gph18B8j+nmuLJLQGAu+K2t3C+b32xs.Xu5T70rJliaUcF71UmkS0Fov3woVVAbHP0dRkhKj.SXDMVkFwvISHBCeJwNELD1vAxon+1V93g27LrcNPS8JYFG3JI+KtR5duNcMVmNJSpEZpldLhIoxCjZtQ1thn2vko82dLb9WhBvUsCFPumOi64y3Gu7YnXdnigJsTenL5f.vP2.CGTBlh1RH.2yowoKn1yfg7VlwBfcSCRrjdbHEk.bJZHmRkYMUwduIAsTYkFZakICsgO.8kjaHlISvvLlLbfXzvwzASlbqUgeY1v+sLpe3etKUpDf51HaWwzqvEJjWN2eUv2iv+3bPVLkKnOVdRIPsb4dFXCBy.3JHN0RriQwZ4Ti0LwJFMhyu5VuHBitYSqgz0uy7TLFp3jZiS7DwZ2NcSyadta5XfmD1oQdt+Qa+TUXgU.q4F8kwadJEow+92sEG5X0V.Y6CAp6UpuSRBWThBQTlZeG6kWKOtm1nnBDEiQy1rEHkwZQWDsiPKPCFRrBKF3K0UIP5eaAIbQwqdrYhaHRzy07G+C+jzra.h27crSs4aT4gwBJoFsoP6gg5n3V.iGPidcjFnv6jl14PmKWo4c.48.FtGvvOfAL.dLMiIfhQLnEdNMtT3P4dtGvPG67BP1kPFtoALnde58QSP4Z8VFs4f1ZrFHqTj6OCAbzmDsfZU4YO+sgmGuJSQuJeMpZy5fOG561rtay5GPaVXHFF69bYkJmyoBOIWwn.fhsv8lEr6lr9efEKyc8N2067CmdGEW4QEVA2HzG6FCKySR0RzKYZGRH2aeMOD1649TFrucbVNsruWkav0k.Ntm0Zjk5jdo1SHDL.3Lgnkv49A0G3ybFGaHgae2yY6kUVcEkpo6K9RlKMbsmko4f1z94eULxNgHlpkjghoThTvjC0L9jArgeWpqdsMLYikWejaZdHqUZ4z24RgDNi4ojfPIMvwNkv53yLM6X9RuKH1i+8qfmGsbKPshLCvfhooF3XbDBbOssbTaveHhf.EwvmYIvLFrbI3yXpYWKu3vqXhFMaGDsnYBVEGut0dvas+tNbRjye8jzNY6ecmzEJ+ZXomfyQ3oCXcftjROoc3zTm8XmemGVLEd6dredy1my2LS+Exl.+4OFrX+4vtXE.QeOWEFkAgqVp4te.6kVONyTxmRN2fJJrFU1aCglTRvXnte1TxPiUQlNdvPyvgpIiA0UBLaZGzgOReGWUtbnqi2j7vGy6iNN+p6zw+e9vLS3TW+8h5qDEa1RlF7rRM2pEH9nQOBdGbZl4hyzAGztGe8q+zUnqMEy7SZCaPv7.znNkgBw7V7RynlGf1QLRhOEVP3hkVlb4besH3uG6Hsa4+LmjkmhiyZcdt7cVCxRu4cHaZSPm0UUfwiQ0VVacc2a2WeMoLdmx9Wbulqdmw5u879pgwIXVu1MjCJA5su+rYjYbyRTGgKaRnBELNtaM.nR4hDMCAFLvw.euI1ea47HOFMKyj6CkHkyKonoAJmRAKzRkGeyJ+iN1ElxDU24+sbtHPe.N3wdF+2.dGduY81TzuEt+O6NWSu3dmF91IWYnnF5+Eubn7JkvCMyZzTFq02TH1QDwTyPhYncLgqDpwiTlACT1a81ca4Box98uD3l+zsby2ut.ujVKpQprb9wNAGirvCwynZLM2zhUq.ECArvbJ5YK3SnKl6SQ7qPd62K6Pb9U1Mm7qS9M2do8JhNO60e2wjoaAOizc7mr.z54oNXtRPDhkZxLgPQVD.ne+.ctbl4VFdd5yaoyfZ5aqfri6ZwVUzc5S+onkwowg5He2lL3zKu7eQ+5u8x
--end-wire-patch--
Thanks so much! I’m away from my computer today, will try it out first thing tomorrow.
Nice work Arvol...... I also checked it....I would recommend adding a "smooth" node after the Y Input do get rid of the dotmatrix effect when changing values fast.
Best wishes
cosmwoe
Best wishes
cosmwoe
