Looking for Resolume Wire programmer
Might as well join the team
Re: Looking for Resolume Wire programmer
100% Great catch!
benneill
Post by benneill »
Thanks so much both of you, it works great! I put in the Smooth node as cosmwoe suggested and it works well. Now I'm working on creating a branching effect so the lines appear to be growing like a plant or other organic, evolving structure.
benneill wrote: Tue Jan 17, 2023 04:42 Thanks so much both of you, it works great! I put in the Smooth node as cosmwoe suggested and it works well. Now I'm working on creating a branching effect so the lines appear to be growing like a plant or other organic, evolving structure.
I already added it in, it should just be a copy/paste for you now
benneill
Post by benneill »
Do you have a suggestion for how I could create that branching effect? Basically so the line could multiply with another controller?
branching off would require some creative feedback like how these pluggins opperate:
https://vjtarian.gumroad.com
You could instance the patch and that would give you multiple lines but they won't branch.
benneill
Post by benneill »
Would I be able to use the Feedback Systems plugin from the site you shared for that or are you saying something would need to be built?
something would need to be built like that.
