Purchased m-audio trigger finger yesterday. Any suggestions about midi mapping? I would be interested to learn how others set it up with resolume.
Also, I read the posts about Ableton integration but I can't say I grasp it all. Recommendations on this topic are welcome, too.
trigger finger
fullscream
here's my setup
4 faders:
one for opacity active layer
the other three for layers 1, 2, and 3 opacity
knobs top row:
one for active layer speed
three for layers 1, 2, 3 speed
knobs bottom row:
1 for clip in
1 for clip out
2 for effects parameters
pads i'm only using 4 right now (yes, it's quite waste, i know
probably will add more assignments later on, or when 2.4 is out
1 pad for active playhead
3 for layers 1, 2, 3 playhead
pads are set to be pressure sensitive, so i use the pads to scratch and restart the clips (tapping)
4 faders:
knobs top row:
knobs bottom row:
1 for clip in
1 for clip out
