Slice screen does not fit correctly into slice transform screen
alexandremix
Post by alexandremix »
https://imgur.com/a/zCmnVjS
As soon as i started to work with slices notthing is making sense
Basically i have 3 screens, but i was tired of having the content so zoomed in to pan across them 3 that now I have the 2 screens on the side repeating the content of the main screen, and the main screen im trying to treat it as a single total screen with most of the content
I have some layers where i want the content of it to totally go around the screen, something to create a border effect.
When i add the slice transform to just show on this screen 1 and choose the scretch option it does something that is not at all normal, please see the imgur link above.
thanks
Re: Slice screen does not fit correctly into slice transform screen
If you change your clip WxH to match the comp it should work.
@Dev's do we think we could discuss having an option to have a drag and drop option that works like the OP has intended, without the need to resize clips or layers? I've seen this issue come up a few dozen times and it always seems to throw people for a loop. :)
