Ndi Scan converter
vladpet22
Ndi Scan converter
Post by vladpet22 »
Hi! I have some issue with Ndi Scan Converter and Resolume (6 version). All on the same MacBook Pro. I launch the scan converter, choose what I need to capture, NDI virtual monitor shows a picture. Resolume defines NDI Scan Converter. But than I put it no layer, it is offline. There is problem?
Re: Ndi Scan converter
Firewalls off?
Are you using the HX version of NDI Scan converter / capture?
v6 won't be able to show NDI HX.
