Audio input not working on Win10, Resolume 7
virginiatoffetti
Post by virginiatoffetti »
I've just updated my Win10, and the audio input stopped working. I have Resolume 7.0.5.
In other terms, I'm trying to make some clips audio reactive (using External FFT) and nothing happens, the computer mic doesn't seem to get any sound into Resolume.
I've set up the audio preferences as follow:
- Audio output device > Driver Audio > Speakers (Realtek Audio)
- Audio input device > Direct Sound > Microphone
I've already checked this: https://resolume.com/support/en/audio-input-no-worky and already did this: Go to Settings > Privacy > Microphone and make sure “Allow apps to access your microphone” is active.
Do you have any tips to solve this please? I'm stuck .-.
Many thanks in advance,
Virginia
Re: Audio input not working on Win10, Resolume 7
You where 99% there ;)
Under external FFT select Left & Right and you should be up and running. :)
