File Looping Issue
Boyden
File Looping Issue
Post by Boyden »
Hi All,
I am having any issue where the clip in Resolume is looping, even though I have set it to continue on.
In Autopilot, I have set the clip to play next clip, which its doing, but not before looping the clip again. So basically, what's happening is the clip is looping AND continuing on to the next clip.
I'm relativity new to Resolume, so I'm sure I've just missed something, but from what I can see there is nothing set that should be causing this.
I have even tried deleting and replacing the clip, but the issue remains. I don't have the same problem with other clips.
Any ideas on what's causing this?
Cheers!
Re: File Looping Issue
Try a 0s transition time.
