Hey!
I am working on a 5300x600 project with 6 CRT screens.
I have two Matrox triple head, so I told Resolume I have two 2400x600 screens.
I use the first screen to display an horizontal image, onto three CRT, and the other one to display independently onto the three others ones.
I work with four layers: One for the first screen (horizontal image) and the three others layers for the three others CRT.
In advanced output, I made this routing:
Screen 1
Slice 1 - input layer 1
Slice 2 - input layer 1
Slice 3 - input layer 1
Screen 2
Slice 1 - input layer 2 (TV1)
Slice 2 - input layer 3 (TV2)
Slice 3 - input layer 4 (TV3)
I want to be able to control effects with a midi controller, and use the composition dashboard to do that, to apply an effect to all screens at the same time. But since I routed my screens/layers/inputs etc (lol) this way, the composition dashboard does nothing...
Any idea?
Mega thanks
CRT and Matrox triple heads routing pb: How to use the composition dashboard with multiple outputs?
georgesgeorges
OnlineZoltán
- Team Resolume
Re: CRT and Matrox triple heads routing pb: How to use the composition dashboard with multiple outputs?
Make your composition as big as all your outputs, play the clips on the areas you want (slice transform can be great help there) and then you can use composition routed to slices, and composition effects.
georgesgeorges
Ok thanks, it's working now
