Sound issue w/upgraade
Upgraded Arena to 7.1.4 and my clips with audio went out of time, had to change to BPM and try to force to correct timing. Downgraded back to 7.13 and it's still messed up now.
Re: Sound issue w/upgraade
Check the sound device settings in preferences, and the speed sliders on composition, groups and clips.
Did all that and all was set as always, the only change was the upgrade to 7.14 and that changed the sound speed.
Dave
Dave
But you say 7.13.2 also does it?illumn8r wrote: Mon Mar 20, 2023 20:57 Did all that and all was set as always, the only change was the upgrade to 7.14 and that changed the sound speed.
it's not the 7.14 update then.
Could you please send us the Resolume log file via the feedback tab in preferences?
