Pre-recorded audio reactive video
FractalMan
Post by FractalMan »
I want Audio to affect my pre-recorded video. It works as expected to record, but with so many knobs to keep track of (even with dashboard) I'm trying to find an automatic solution where I don't need to hit record and turn a bunch of knobs, better to have all that set up ahead.
Basically I want to adjust the video parameters based on audio keyframes. How would I map this - Envelopes+Timeline? I want the audio to drive the video, and be able to adjust parameters with keyframes.
A couple of things: I'd like to create envelopes for various parameters based not on just the length of video clip, but instead on the audio level changes.
I'd like to more exactly sync the audio and video better than just hitting the record button.
You guys rock, and the new update solved most of my recording delay issues. Kudos.
Re: Pre-recorded audio reactive video
FFT animation has a + mode which advances the parameter based on audio, maybe that could do what you'd like?
