8 x 4K30 outputs??
rbullockSIAV
8 x 4K30 outputs??
Post by rbullockSIAV »
Looking to send out 8 x 4K30 signals to a bunch of LCDs.
Current setup is a MacPro and 2x Decklink 8ks. It works, but not really good.
Want to move to a GPU only environment. This is what I was looking to build:
Threadripper 4.0Mhz 16-core
Main GPU/GUI: A4000
Output GPU's: 2 x A4000
Nvidia Sync II
The resolution of the matrix is 16384 x 4214.
Would NVLink allow Resolume to use multiple GPU's for processing?
I think one A4000 is capable of handling this resolution.
The AMD W6800X we currently use is running at only 22% in our current MacPro rig.
Any insights would be great.
