Second output screen black
evilkilig
Post by evilkilig »
I use MacBook Pro 2.3 GHz 八核Intel Core i9, Intel UHD Graphics 630 1536 MB,macOS Ventura13.3.1(3072 × 1920), Arena 7.14.1
Normal display
When I cast my computer to the projector, the second screen doesn't show anything
When I leave the projection state and reopen the software, the composition monitor also goes black
Re: Second output screen black
How do you "cast" the display?
Do you have a dedicated GPU in the machine? https://resolume.com/support/en/tech-specs
evilkilig
Post by evilkilig »
Zoltán wrote: Thu Apr 20, 2023 06:46 How do you "cast" the display?
Thanks for your reply ;) i think it is not "cast",it is mapping or mirror..? i used"screen mirroring"to project.As well as I confirmed the list, my device is up to the minimum specifications
The intel 630 doesn't meet the minimum specs unfortunately, that's why I asked about a dedicated GPU.
Cast for me would mean sending via software like airplay, Mirror would be duplicating your screen.
Do you use the OS display mirror, or do you have Resolume send it to your external display?
evilkilig
Post by evilkilig »
Zoltán wrote: Thu Apr 20, 2023 11:07 The intel 630 doesn't meet the minimum specs unfortunately, that's why I asked about a dedicated GPU.
Please forgive me for not being very good at English so there is a bias in the expression, I am trying to describe it as clearly as possible
Since Intel is not mentioned in the list, And I don't know much about this kind of hardware,I assume that my computer equipment meets the minimum requirements
I use "mirror screen"to connect with projector as my second screen,and i clicked "output-display" and draw the new Preview window to the second screen area.
