DRAMATIC FPS DROP ISSUE
l.toni@techplanet.it
Post by l.toni@techplanet.it »
HI,
I'M EXPERIENCING A HUGE PROBLEM WITH MY RESOLUME ARENA SYSTEM.
MOTHER BOARD ASUS X299 PRO
CPU INTEL i9-10980 XE 3.00 GHZ
RAM 32 GB 3200
GRAPHIC CARD AMD W6600 8GB
BLACKMAGIC QUAD DUO
STATS REPORT CPU USAGE 8% RAM USAGE 32% GPU USAGE BETWEEN 17 AND 55%
Two 4k 3860*2160 screens connected plus fhd control monitor.
i need to use all 8 live inputs from BM .
When i activate the inputs, the fps start to drop and "float", up to reach even 14 upon the 50 set in the composition.
I have also the really weird problem that if i reduce the window in the control monitor, both the output start flickering , with resolume arena working between 2,3 and 3,4 fps!!!!!
Re: DRAMATIC FPS DROP ISSUE
The FPS you set in the composition settings in a maximum cap. The actual value will depend on the actual system load.
AMD cards don't seem to produce the expected performance with Resolume nowadays.
Do you also see the same FPS drop in the preview counter, when you play the same amount of videos?
