Hi yall!
I have been trying to figure out a way to have my clip playback to be audio reactive to create a video scratching effect. Been trying to create something in Wire, but have not found a way to replicate the Transport section from Arena to connect the playback to external FFT for it to bounce back and forth while playback is moving forward.
Is there an already existing way to do this, or a resource I am missing to try and learn this?
Audioreactive Playback Control (scratching) - Wire
Mrimprobable
Re: Audioreactive Playback Control (scratching) - Wire
In Wire you will need to use a Video Player node and then play with the phase, then set your patch as a source (or FX if you want to use it as an overlay or mask)
