I mindlessly followed the prompts to upgrade, and now my output is watermarked.
I am totally happy running my prior version. Is there a way to revert to prior version??
My license is for up to 7.13.2
I upgraded to 7.15
Thanks,
Rob
Upgraded by mistake, now watermarked. Can I revert
Re: Upgraded by mistake, now watermarked. Can I revert
sure, uninstall Resolume and install the version you need. You'll find the download here:
https://resolume.com/download/ scroll down till you see the drop down menus where you can choose your version.
Greetings
Greetings
Do you like outlines? Easy Outliner on Juicebar
