Text string from OSCPilot to Resolume
kvoldsol
Post by kvoldsol »
I’d like to send a text string from an OSCPilot text label to Resolume.
How can I write the address and settings on the OSCPilot side to communicate with the text animator of Resolume ?
Thanks a lot,
Mike
Re: Text string from OSCPilot to Resolume
If you enter OSC shortcut mapping, click on the text field in the Text animator clip. That will show you the address you can send the String to.
For example Text animator Source will give you something like this:
/composition/layers/1/clips/5/video/source/textgenerator/text/params/lines
