Dynamic range using Resolume Arena
wasimo
Post by wasimo »
Hello everyone,
I got the problem of a bad dynamic range using Resolume Arena. I just used a white colour in my composition to test this range because gradients don't look that smooth. When I started decreasing the brightness, starting at 100%, my lights are completly switched off at 15% and below.
Is there any solution to get a better dynamic range?
Also in between 15% and 100% not every value is possible. So for example there is no difference between 15% and 16%.
Few more details:
- I use the free version of the current resolume arena version, but also tested a old version (7.3.1)
- I use Ws2812b LED stripes and WLED for the connection. I think this wont be the problem, because if I use other software than resolume, every value is possible (1%, 2%...)
thanks in advance,
Simon
Re: Dynamic range using Resolume Arena
Try changing the Gamma in the Fixture profile you use.
https://resolume.com/support/en/fixture ... correction
wasimo
Post by wasimo »
This solved my Problem.
