(3) 4K outputs at 60hz with 3060ti or 4070?
smoresahoy
Post by smoresahoy »
Is this possible with a 3060ti or 4070? I know in the past, only 80s and up were able to comfortably handle three 4k outputs at 60hz?
Will it work if it's playing 4k footage as well?
Re: (3) 4K outputs at 60hz with 3060ti or 4070?
My old 1060's & 2070's could do (3) 4k@60 outs. The bottleneck will be how many layers you can use at once.
smoresahoy
Ahhh okay, I'll probably keep my 3060ti for now. It's not a full show computer, just for emergencies or backups.
A3logicsusa
Post by A3logicsusa »
The NVIDIA RTX 3060 Ti would have been an appropriate choice for optimum performance in 4K at 60 Hz due to its excellent graphics capabilities and smooth play. 8-) 8-)
