Hey,
during a important rehearsel yesterday all my clips which were set to 'Timeline' in the 'Transport'-section of them were suddenly not playing anymore when I triggered them. I had to switch them all in a hurry to 'BPM-Sync', but which was a very insufficient solution, because I was relying on the native tempo of the clips.
All Clips rendered in DXV 3, on Resolume Arena 7.3.2, on a Macbook Pro 2012 15inch, on MacOSX Catalina.
If i create a new comp it works normaly.
In the old comp the problems persists, even after closing and restarting resolume.
Help appreciated
K
Timeline-playmode stops working!
Re: Timeline-playmode stops working!
Sounds like your comp or group speed control is set to 0
baustellen
Wow, easy solution.
A bit embarassing for me, but a easy solution.
thank you.
thank you.
avclubvids
This was my problem too, just coming here a year later to say thank you for this solution!
