Suddenly half of the MIDI maps that I've had in the 'shortcuts' folder inside Resolume Arena in my documents (on a PC, windows 10) are not showing up within Resolume when I go into MIDI map input view. Only the defaults + a select few really old ones show up.
And when I try to copy new maps into the shortcuts folder, none show up in the program when I open it, under the drop view menu.
Tried uninstalling + updating Resolume, even reset the PC. Still same issue. Please help!
MIDI Maps not showing up in Resolume
Re: MIDI Maps not showing up in Resolume
Sounds like damaged xml or duplicate preset IDs, could you attach one of them (zipped)?
Was there an unclean shutdown?
