I have a problem with other users clearing specific clips from the composition that need to remain in place. Is there a way to lock a clip so that it cant be removed without a password or something?
I know persistent clips will stay up on multiple decks, and locked clips look like they just cant be clicked off of on the layer, but in a layer with multiple clips playing on a shuffle, how can I keep certain ones unclearable?
is there a way to lock clips so other users cant clear them
RJD-studios
Re: is there a way to lock clips so other users cant clear them
Clearing clips like they are stopped, or do the users remove the clips?
- rawdesigns
+1
I have the venue computer for nightclub and other vendors dragging in files and messing up my composition/midi settings. As of now I have a separate composition for them and open that after nightclub shift
