Im running a AMD Athlon 1.4ghz, .5gbddram, NVidia Nforce mobo with onboard gforce2 + extra pci voodoo banshee for dual head output...
Most of the problems Im having seem to be with the dual head support. Most users seem to be people with dual head cards such as the matrox crew.. have you tested the dual head support with two different cards in the same pc? I have this configuration ( left desktop main window.. right desktop output window) and Im having problems with the config window that you get when you right click on a clip window popping up on the other desktop (sometimes over the top of the main output window) you can see that its in the right position to fit around the clip , but completeley the wrong desktop. This is fine however you cant switch off an effect on a clip or change the play mode (loop, once, pingpong etc) without reloading it , or you risk seeing the config window over the main output!!
the same goes for the save clip bank window ( I presume that this window shouldnt pop up over the top of the main output on my right hand desktop?)
I think both these problems must be to do with my configuration but it is still a bug. Ive noticed that if I click on the monitor identifyer for the main resolume window it will togle between the two displays.. As in if I tell it to go to monitor 1 it goes to my actual monitor 2, and If i then re-click on the 1 symbol it will switch back to the other desktop, but my task bar will then refuse to hide as if the window isnt there....?? any suggestions.
Im also having problems with midi control of effects.. Im using a simple 12 fader midi controller, if I use an effect that can be controlled by a fader progressively for instance rotozoom the start of the fader will be 1 instead of o and the end scale will be 127 instead of 128. I know my controller is putting out the correct value as i use it for music work on the same pc... It would be nice if you could have value of 0 so that the effect can be completley switched off while its on..
It would also be nice if the program could remember its last window position and resolution for the main output..
Im also having problems with some of my .mov quicktime movies not playing(infact most of them) . Also some random avi`s dont play when they do in windows media player...(only a few maybe 5% dont play)
Are there any issues with file size / codecs that resolume has problems with?
Is anyone else having this problem?
Does the developer know about it?
Does the developer want any more beta testers? ( ive done proffesional testing before)
Ax
alan@aptevents.com
