Is there a way to remove the lag caused by playing four simultaneous layers? Or are the specs of my laptop not enough?
Intel Core i9 - 12900H
Nvidia 6GB 3060
32 GB DDR5
Multi layer lag
Re: Multi layer lag
Are ALL of your video files Encoded to DXV3?
What is your comp size?
How many outputs are you using?
How many Layers are you using?
I toured with a 3060 for a while and was able to do 6 layers of 4k sent to (2) 4K outputs with no issue at all.
Re: Multi layer lag
Ah yes, that seemed to be the issue, one of the videos was indeed h.264 instead of DXV3.Arvol wrote: Fri Jun 30, 2023 16:19 Are ALL of your video files Encoded to DXV3?
Thanks a lot, and sorry for the late reply!
