Is it possible for layers to be controlled individually across different compositions?
pettypoh
Post by pettypoh »
hi,
i have been trying to figure this out for awhile.
is there anyway to have the layers to NOT have the same transitions across different compositions?
for example, at the moment, if layer 1 has a 1sec transition for my first composition, then all the other compositions with clips in layer 1 behave the same way, but i wish to only have the 1sec transition for first composition
thanks!
Re: Is it possible for layers to be controlled individually across different compositions?
Compositions have a set of layers, and a group of decks.
I think you might mean having different layer settings for decks?
In Resolume, the compositions have layers, and decks hold the clips.
Layers can't be changed by the decks, but clips can set the layer blend modes if you'd want to:
https://resolume.com/support/en/clips#video-properties
pettypoh
Post by pettypoh »
hi zoltan,
thanks! yes you are correct, i wanted to refer to decks, not compositions
as per what you mentioned, the clips can have different blend modes, but there is no way to control "transition timings" via the clips only, is that correct? i have only managed to control transition timings between clips via the layers
Indeed, clips can't set the transtition time yet. We have a ticket for that.
Using animation on clip opacities, could make longer fade in times:
https://resolume.com/support/en/parameter-animation
