i dont know if this applies just to the XM1 (GL1 in the USA) but the camera seems to have a power saving utility which means it cuts out after a minute or two of not being used (i.e. being recorded on). does anyone know if there's a way of preventing this, and if not, is there a way of resolume in the future sending some sort of info to the camera to tell it that it's being used and not to cut out? otherwise the only option left is to set the camera recording the entire time so it can be used as a source in the mix, hence it cant be used quite so quickly or easily to switch over to record the mix or be used as an alternative source (by playing back a dv tape) should my computer crash during a performance.
any ideas or info on expreience with this camrea would be much appreciated.
Justin
XM1 compatabliltiy
therandelman
