Clip Manager (Show template prep)
kai
Post by kai »
Clip Manager
  • A separate popup similar to media manager that lists all clips perhaps with a toggle-able thumbnail column where clips can be renamed as well as expanded to see a list of current effects assigned to each clip.
  • This clip manager list should be able to be saved to a text file format or even templates that can be filled in so that shows can be planned out.
  • A user creatable template system could be used so that each Resolume user can customize the layout of the "plan guide" that can include a list/pictures of all the clips used in the show.
  • An option to include the yet to be created feature of "clip notes"
