How do I get the FFT Gain to use audio from Ableton?
frogeer
Post by frogeer »
Hello guys. How do I get the FFT Gain to use audio from Ableton? I have an audio interface (M-Audio M-Track Solo). I'm also using Windows.
Re: How do I get the FFT Gain to use audio from Ableton?
VB-Cable makes a loopback device for local machine app to app sharing.
frogeer
Post by frogeer »
Can you tell me how to go about it? I've been trying to figure this out for hours but still can't seem to figure it out. I saw another post like mine where you also commented:
viewtopic.php?uid=289276&f=12&t=22410&start=0
I downloaded Voicemeter as well but still can't figure out how to use it the way I want. Pls help, thank you.
Figured I would just reply here as there is another user asking as well. :)
LMK if it's not clear enough and I can film a quick tutorial.
